It seems that only the first material clause in a link is used for the whole link.
For example for a simple Minion Dave with blue overalls and yellow "body":
 <!-- DAVE -->
  <link name="dave_link">
    <visual name="bottom_half_dave" >
      <origin xyz="0 0 0" rpy="0 0 0" />
      <geometry>
        <cylinder length="0.045" radius="0.0375" />
      </geometry>
      <material name="solid_blue" />
    </visual>
    <visual name="top_half_dave" >
      <origin xyz="0 0 0.045" rpy="0 0 0" />
      <geometry>
      </geometry>
      <material name="solid_yellow" />
    </visual>
    <visual name="head_dave" >
      <origin xyz="0 0 0.625" rpy="0 0 0" />
      <geometry>
        <sphere radius="0.0375" />
      </geometry>
    </visual>
  </link>
  <joint name="joint_dave" type="fixed">
    <parent link="base_link"/>
    <child link="dave_link"/>
    <origin xyz="-0.04 0 0.250" rpy="0 0 0" />
  </joint>
Will always use the solid_blue of the bottom half for the other two visual objects in the dave_link.
Is there a way (other than making each part a separate link with joints)?
Unfortunately, it looks like this is a bug that was reported in 2015 and is still unresolved. The URDF link documentation here says, in part:
Note: multiple instances of tags can exist for the same link. The union of the geometry they define forms the visual representation of the link.
I don't know if the rviz bug is truly a bug or if it's supposed to be treating all visuals within a link as one fused object, but your options seem to be to either split out your colored components into their own links or make your own mesh and apply a texture.
