Let the general forward rate kinematics equation for a serial mechanism be given as follows:
$$ \begin{bmatrix} \boldsymbol{v} \\ \boldsymbol{\omega} \end{bmatrix} = \begin{bmatrix} \boldsymbol{J}_1 & \boldsymbol{J}_2 & \cdots &\boldsymbol{J}_n \\ \end{bmatrix} \begin{bmatrix} \dot{\boldsymbol{q}}_1 \\ \dot{\boldsymbol{q}}_1 \\ \vdots \\ \dot{\boldsymbol{q}}_n \end{bmatrix}$$
The Jacobian, $\boldsymbol{J}_i \in \mathbb{R}^{6}$,columns are formed by a direction and moment vectors, i.e., $\boldsymbol{s}_{i\parallel} $ and $(\boldsymbol{s}_{i\parallel} \times \boldsymbol{l}_i)$, respectively. I know $\boldsymbol{s}_{i\parallel}$ is a direction vector which is only dependent on the joint angles and $\boldsymbol{l}_i$ is a position vector to the location of $\boldsymbol{s}_{i\parallel}$. If $\dot{\boldsymbol{q}}_i$ has a unit of $rad/sec$, what would be the unit of $\boldsymbol{s}_{i\parallel} \times \boldsymbol{l}_i$ to get an approperiate dimension for $\boldsymbol{v}$ and $\boldsymbol{\omega}$?
Thank you in advance
