I seem to misunderstand something crucial regarding finding the force vector in the process of DMPs: The way I understand it, I should come up with a dataset of trajectories $\{y_i\}_{i=1}^n$, and calculate a set of "True-labels" that are the forces associated with those trajectories: $\{f_i | f_i=\ddot y_i - \alpha_y(\beta_y(g-y_i)-\dot y_i)\}_{i=1}^n$. Next, I can minimize the squared differences between the approximation $\hat{f_i}$ (which is a linear combination of Gaussians) and $f_i$.
If this is all correct, why do I even need the approximation $\hat{f}$? don't I always have the values of the real force $f$, as I can always calculate it given the equation of motion? In other words, If I want to follow a trajectory $y$, then I need to apply the force $f(y)$, which is given by an $O(1)$ computation
Perhaps my error revolves around the idea that $\hat{f}$ is some generalization of all the different $f_i$'s? as in that $\hat{f}$ contains the information of all forces that are possible. If that is the case - I think for example of a robotic bird. A robotic bird does not have a set of common trajectories - in some cases, it may go in circles, and in other cases, it may go straight up. In that case, how can the DMP process generalize the force to account for all possible movements of the bird? I find it hard to believe that a linear representation of the forces of the wing could contain all that information
Thank you for your answers!
The idea of Dynamic movement primitives is to encode a target motion into a flexible machinery that can quickly generalise to new instances, but still imitating the overall shape of the target motion. To get the new trajectories, it can be enough to specify few parameters, for instance the initial and final cartesian positions, and the DMP weights will tell you the entire new trajectory.
In the language of machine learning, the DMP weights are the neural network weights, the initial trajectories are the training dataset, and the new parameters are a test instance. It is not an exact analogy, since training and test sets are not from the same distribution here, but I find it helpful.
Regarding your last paragraph, DMPs cannot generalise too much. You can "train" a DMP with $\hat{f_i}$ from a single $y_i$, where $y_i$ is the path to be imitated. So you can get a DMP with $\hat{f_1}$ for a circular movement and a DMP with $\hat{f_2}$ for a linear movement. The whole idea is that even complicated movements can be composed into a basis (as in linear algebra) of a reasonably small number of primitive action building blocks.
If you know in advance the exact trajectory $y$ that you want to perform, you don't need to use this formalism. But this is rarely a realistic assumption, since slight variation in your environment means that every trajectory (e.g. for a walking robot) will be different. Indeed computing this new trajectory in real time may be time consuming, it's much faster to adapt an existing DMP to generate a new trajectory, while only fixing few parameters (rescale factor, or endpoints). This has the added benefit of making your trajectories all consistent with the path you are imitating, which may have been recorded to be particularly harmonious.
See this blog for more info.
  • $\begingroup$ If I understand you correctly, $\hat{f}$ is indeed the generalization of forces $\{f_i\}$ that was given by a set of trajectories $\{y_i\}$, but those should all be similar, at least in the sense that they describe similar movements (as in only circular motions, or only upwards motion)? Regardless, If you agree that $f_{target}$ is easily obtained by substituting $y_{target}$ to the differential equation, can you clarify why we still need $\hat{f}$? $\endgroup$
    – Hadar
    Aug 19, 2022 at 8:45
  • $\begingroup$ Edited a bit, with answers to your questions. $\endgroup$
    – Rexcirus
    Aug 19, 2022 at 9:52
