I am actually doing an obstacle avoiding car. So, I bought Arduino UNO and L293D motor driver and four motors, servo motor and ultrasonic sensor. After the connections I have kept 10v li-ion battery. My problem the servo and sensor and motors are not working. BUT, the LED is glowing on both UNO and motor driver. I don't understand what's the problem?
(WHILE CONNECTING THROUGH USB CABLE THE MOTOR IS WORKING GOOD.)
Here my code,
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 100
#define MAX_SPEED 150
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_64KHZ);
AF_DCMotor motor2(2, MOTOR12_64KHZ);
AF_DCMotor motor3(3, MOTOR34_64KHZ);
AF_DCMotor motor4(4, MOTOR34_64KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
void setup() {
myservo.attach(10);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
void loop() {
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=25)
moveStop();
delay(100);
moveBackward();
delay(200);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
else
turnLeft();
moveStop();
else
moveForward();
int lookRight()
myservo.write(50);
delay(500);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(500);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(100);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2)
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet);
motor3.setSpeed(speedSet);
motor4.setSpeed(speedSet);
delay(5);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(5);
void turnRight() {
delay(500);
void turnLeft() {
delay(500);
[1]: https://i.stack.imgur.com/9Sxy6.jpg
