I have a question related to the superposition in state space equation. Suppose I have a state space equation below \begin{equation} \frac{d}{dt}X = AX + B\begin{vmatrix} u_1(t)\\ u_2(t) \\ \end{vmatrix} \end{equation} where X is the state vector, A, B are constant matrixes. u is the input time varying signals.
Now assume u can be expressed as \begin{equation} u_1(t) = c_1\cos(w_1t)+c_2\cos(w_2t)\\ u_2(t) = d_1\cos(w_1t)+d_2\cos(w_2t)\\ \end{equation} where c1, c2, d1, d2 are constant coefficients, and w1 and w2 are different.
Can I rewrite the state space equation into the following two equations: \begin{equation} \frac{d}{dt}X_1 = AX_1 + B\begin{vmatrix} c_1\cos(w_1t)\\ d_1\cos(w_1t) \\ \end{vmatrix} \end{equation} and \begin{equation} \frac{d}{dt}X_2 = AX_2 + B\begin{vmatrix} c_2\cos(w_2t)\\ d_2\cos(w_2t) \\ \end{vmatrix} \end{equation}
And then I solve for time-domain steady state expression for X1 and X2. The final time domain expression for X would be \begin{equation} X = X_1+X_2 \end{equation}
Is there anything wrong with this method?
That's correct!
It's the magic of linear systems.
Find it also on Wikipedia.
    $\begingroup$ One does need to ensure that the initial conditions also satisfy $X(t_0)=X_1(t_0)+X_2(t_0)$. $\endgroup$
    – fibonatic
    Commented Jun 8, 2022 at 9:52
  • $\begingroup$ Yes, definitely, which basically enforces a constraint on one of the substates $X_i(t_0)$ since we're initially given with $X(t_0)$. $\endgroup$ Commented Jun 8, 2022 at 10:04
