I found the patent on google patents.
- The method of fabrication:
Each base side of a protrusion is attached to a base side of an adjacent protrusion by a flexible seam or continuous fold, and each protrusion foldable about a plane dividing the protrusion into two parts from an axially-extended condition in which the base sides are substantially parallel to an axially-contracted condition in which the protrusion encloses a volume larger than that enclosed in the axially-extended condition.
A pair of axially-aligned end terminations is formed at each end of the enclosure with one of the end terminations being hollow. A pair of end connectors are each coupled to respective end terminations with one of the end connectors having an axial bore which provides fluid communication between an interior of the hollow enclosure and a source of pressurized fluid.
A provision of a plurality of protrusions articulating about their base seams and sides allows the use of substantially non-elastic material for the membrane of the hollow enclosure or bladder, thereby avoiding failure problems associated with elastomeric material.
Moreover, the hollow enclosure may be made from flat sheet material which is strong enough to withstand standard pneumatic line pressures. Alternatively, the hollow enclosure may be a single-curved hollow membrane.
Moreover, the output force exerted and work done by such an actuator is relatively large due to the large change in volume and a large percentage contraction achievable by the enclosure. The percentage contraction is large due to the ability of the enclosures to articulate without excessive radial bulging.
Furthermore, if the hollow enclosure is made from flat sheet material, the volume enclosed by the actuator in the axially-extended state becomes significantly minimized, thus increasing actuator efficiency.
Images of certain parts:
FIG. 9 is a perspective view of a four-sided pyramidal protrusion forming one of several which comprise a hollow enclosure.
FIG. 10 is a perspective view of a truncated pyramidal polyhedron which is adapted to form one of the plurality of polyhedrons of the hollow enclosure.
FIG. 11 is a perspective view of the forces on an element of fabric of the hollow enclosure.
FIG. 12 is a schematic force diagram showing the fabric-cable interaction.
impregnated para-aramid fiber fabric
in the quote you posted? Are you looking for something else? $\endgroup$
