I'm using Webots to model an irregular polygon floor for a coverage problem. I want to define the floor using the coordinates of the vertices. So far I have been able to generate an irregular polygon with desired coordinates using polygons.wbt. But I'm not sure if this would function correctly as the "floor" or "ground" for the robot to go over.
1 Answer
Webots offers defaults of some object floors in the ~/projects/objects/floors/protos/
directory from your Webots HOME directory. These however don't give you the option to modify the floor on the basis of coordinates.
To do what you have asked, however, will require you to create a new PROTO file that you can do by playing around with the instructions as given here. Another stack user had a question regarding changing the coordinates of the origin of the floor and you may want to check that out too.
