I would like to use a Kuka/abb 6 axis robot and a machine vision system to pick and place a variety of metal drill bits in size ranges from 0.5mm (ascending up 0.5mm per cylinde) to 13mm in metric and then 1/16 of an inch ascending to 9/64 of an inch. The machine would not have to differentiate between the bits, niether drill bit would weight more than 1kg.
Crucially at the beginning and end of the picking and placing I would like to inspect the very tip of the cylinders to be inspected for a 118 degree chamfer on one end of the bit which should be present regardless of drill diameter of length.
I am lead to believe that if the drill bits are placed end up on a conveyor belt and always the the same place its relatively low cost but crucially if the kuka 6 axis robot has to find the drill bits then the cost increases dramatically, is this true?
  • $\begingroup$ I would be happy to arrange the drill bits sharp side down so they could be 'picked up' with the use of a traditional drill press chuck which could be tightened and loosened automatically. Though I have no idea how this would be controlled and monitor. $\endgroup$
    – user2660
    Jan 24 '14 at 20:01
  • $\begingroup$ By cost if you mean financial cost, then yes it is true. $\endgroup$
    – NKN
    Apr 25 '14 at 15:15
