when an obstacle is in front, the Arduino car should turn left or right. But it is not turning properly. So, what can be the problem?
    $\begingroup$ Welcome to Robotics SAI MANI, but I'm afraid that it is not clear what you are asking. We prefer practical, answerable questions based on actual problems that you face, so it's a good idea to include details of what you want to achieve, what you tried, what you saw & what you expected to see. Please take a look at How to Ask & tour for more information on how stack exchange works and work through the Robotics question checklist to edit your question to make it clearer. $\endgroup$
    – Ben
    May 10 at 18:14
  • $\begingroup$ when an obstacle is in front, the Arduino car should turn left or right. But it is not turning properly. So, what can be the problem? $\endgroup$
    – SAI MANI
    May 11 at 12:34
    $\begingroup$ This is a fairly open-ended question because it could be a lot of things going wrong. So this question is in danger of being closed. Furthermore, you didn't provide nearly enough information for us to help you. What is the mechanical chassis? How is it wired? What are the sensors to detect an obstacle? What is the code doing? There could be an issue at each of these levels. I suggest you isolate the problem yourself and if you still have an issue, come back here with a more specific question. $\endgroup$
    – Ben
    May 11 at 14:04
  • $\begingroup$ @SAIMANI what does the question have to do with torque? ... please edit the title so that it matches the rest of the question $\endgroup$
    – jsotola
    May 23 at 0:24
