trying to run RtabMap on my realsense-435 device. I've set up all the topics and made sure they are published and subscribed, nevertheless, RtabMap gives me this error:
[ WARN] [1649509757.946524434]: /rtabmap/rgbd_odometry: Did not receive data since 5 seconds! Make sure the input topics are published ("$ rostopic hz my_topic") and the timestamps in their header are set.
/rtabmap/rgbd_odometry subscribed to (approx sync):
/rtabmap/odom \
/dynamic_image \
/dynamic_masked_image_raw \
/sync_camera_info
P.S.: I've synced all these ( the last three topics), therefore there aren't any delays among them.
/rtabmap/odom
topic doesn't get published. I'm guessing the issue might have been raised from a bad tf tree??!!
any help is appreciated
the codes I ran:
roslaunch realsense2_camera rs_camera.launch align_depth:=true
then
roslaunch rtabmap_ros rtabmap.launch rtabmap_args:="--delete_db_on_start" depth_topic:=/dynamic_masked_image_raw rgb_topic:=/dynamic_image camera_info_topic:=/sync_camera_info approx_sync:=false
the three topics(i.e./dynamic_masked_image_raw /dynamic_image /sync_camera_info) are published with the same timestamp and contain the frames and camera info.
each terminal is sourced with the specific workspace.
out put of rostopic hz (the topics)
/dynamic_image 16.09 0.04809 0.09111 0.008274 354
/dynamic_masked_image_raw 16.09 0.04802 0.09153 0.008369 354
/sync_camera_info 16.09 0.048 0.09235 0.00834 353
full output error:
[ WARN] [1649758359.612186938]: /rtabmap/rtabmap: Did not receive data since 5 seconds! Make sure the input topics are published ("$ rostopic hz my_topic") and the timestamps in their header are set. If topics are coming from different computers, make sure the clocks of the computers are synchronized ("ntpdate"). Parameter "approx_sync" is false, which means that input topics should have all the exact timestamp for the callback to be called.
/rtabmap/rtabmap subscribed to (exact sync):
/rtabmap/odom \
/dynamic_image \
/sync_camera_info \
/rtabmap/odom_info
