I used a raspberry pi 3 model B and a camera to make a robot detect fire, using https://www.youtube.com/watch?v=-ZyFYniGUsw However I am not sure how to make this robot move after it detects fire. The L298N motor driver (DC motors are connected to this motor driver) and a logitech camera of this robot are connected to the raspberry pi of this robot. I know that it maybe better to use fire sensors to detect fire, however for my project I decided to use a camera.
My last lines of code in the raspberry pi terminal are (these are same as the lines of code at about 10:41 in the youtube link above except instead of using android.tflite, fire.tflite is used):
- source tflite/bin/activate
- cd examples/lite/examples/object_detection/raspberry_pi/
- cp ~/Downloads/fire.tflite .
- python detect.py --model fire.tflite
So is there a way to make the robot move using raspberry pi each time it detects fire?
Update: The following is a more detailed description of the problem (Note if non of the links below work remove the full stop at the end of the link and try again):
Hardware setup
The pin configuration of the raspberry pi (RPi) 3 model B is at https://www.jameco.com/Jameco/workshop/circuitnotes/raspberry-pi-circuit-note.html The IN3, IN4 and ENB pins of the L298N motor driver is connected to GPIO 17, GPIO 27 and GPIO 22 respectively of the RPi model B. The OUT 3 and OUT 4 pins of the L298N motor driver is connected to a DC motor. A male to female jumper wire is connected to the ground pin of the L298N motor driver and to the ground at the GPIO header 6 at https://www.jameco.com/Jameco/workshop/circuitnotes/raspberry-pi-circuit-note.html. A male to male jumper wire is also connected to the ground pin of the L298N motor driver and to the ground of a 11.1V battery. A male to male jumper wire is connected to the +12V pin of the L298N motor driver and to the other pin of the 11.1V battery. The display connector of the RPi is connected to a mini display.
Software setup
I took about 70 images of fire to be used as training data. Then I took about 10 images of fire to used as validation data. Then I annotated the fire in each of the images of the training data and validation data using the LabelImg (or labelimg) software. Then I went to the following google colab (GC) link on raspberry pi: https://colab.research.google.com/github/khanhlvg/tflite_raspberry_pi/blob/main/object_detection/Train_custom_model_tutorial.ipynb This link was in the video description at https://www.youtube.com/watch?v=-ZyFYniGUsw. In the GC link above I logged in, then selected “runtime”, then selected “change runtime type”, then selected “GPU” as the “Hardware accelerator” and then selected “Save”. Then I uploaded my previously annotated images of training data and validation data in a zip folder called “fire_detectororigpics5.zip” to GC by using the upload option on the left side of GC. Within this zip folder there is a folder named “fire_detectororigpics5” then within this “fire_detectororigpics5” folder there are two folders one folder named “train” which contains the training data and another folder named “validate” which contains the validation data. Then I selected connect in GC which is that same as about 5:22 in the youtube link (YL) above. Then in GC under “Preparation” I selected the play button which is the same as about 5:30 it the YL above. Then in GC under “Import the required packages” I selected the play button which is the same as about 5:38 it the YL above. Next under the “We start with downloading the dataset” in GC I remove the following code:
!wget https://storage.googleapis.com/download.tensorflow.org/data/android_figurine.zip !unzip -q android_figurine.zip
Which is shown at about 5:56 in the YL above and replaced this code with !unzip -q fire_detectororigpics5.zip Then I selected the play button to the left of this !unzip -q fire_detectororigpics5.zip code
Then under the “Train the object detection model” at GC I replace train_data = object_detector.DataLoader.from_pascal_voc( 'android_figurine/train', 'android_figurine/train', ['android', 'pig_android'] )
val_data = object_detector.DataLoader.from_pascal_voc( 'android_figurine/validate', 'android_figurine/validate', ['android', 'pig_android'] )
as shown at about 6:11 in the YL above, with train_data = object_detector.DataLoader.from_pascal_voc( 'fire_detectororigpics5/train', 'fire_detectororigpics5/train', ['fire'] )
val_data = object_detector.DataLoader.from_pascal_voc( 'fire_detectororigpics5/validate', 'fire_detectororigpics5/validate', ['fire'] )
code. Then under the “Step 2: Select a model architecture” in GC, I pressed the play button to the left of spec = model_spec.get('efficientdet_lite0') code which is the same as about 6:35 in the YL above. Next under “Step 3: Train the TensorFlow model with the training data” in GC, I pressed the play button to the left of the following code model = object_detector.create(train_data, model_spec=spec, batch_size=4, train_whole_model=True, epochs=20, validation_data=val_data) which is the same as about 6:40 in the YL above. After this, under “Step 4” in GC, I selected the play button to the left of the following code model.evaluate(val_data) which is the same as about 7:23 in the YL above. Next under “Step 5” in GC, I replaced the code that is model.export(export_dir='.', tflite_filename='android.tflite') which is the same code as shown about 8:04 in the YL above, with model.export(export_dir='.', tflite_filename='fire.tflite')
Then I selected the play button to the left of this model.export(export_dir='.', tflite_filename='fire.tflite'). Then under “Step 6” in GC, I replaced model.evaluate_tflite{‘android.tflite’,val_data} which is the same as about 8:15 in the YL above, with model.evaluate_tflite{‘fire.tflite’,val_data} then I selected the play button to the left of model.evaluate_tflite{‘fire.tflite’,val_data}
Next I selected the “Files” tab on the left of GC, then right clicked the document named “fire.tflite”, then selected “Download” Then I opened the raspberry pi terminal and entered the following code:
• source tflite/bin/activate
• cd examples/lite/examples/object_detection/raspberry_pi/
• cp ~/Downloads/fire.tflite .
• python detect.py --model fire.tflite
The preceding four lines of code opens the Logitech webcam connected to the raspberry pi and detects fire whenever fire is put in front of this camera
