Is there's any library to interface the Jetson Nano GPIO? There's the official Python interface, and there is an unofficial c++ interface which is working through the filesystem, and I'm interested in the direct register access. There is a post here by someone who claims he has achived it, but before I re-imlement the reference manual, It would be great if someone already did it.
  • $\begingroup$ what is preventing you from running tests? ... it is expected that you do research and attempt a solution before you post here $\endgroup$
    – jsotola
    Feb 8, 2022 at 2:08
  • $\begingroup$ I don't understand the question, I'm not running any test, I'm searching for a c++ library that access gpio through direct register memory $\endgroup$
    – Mercury
    Feb 9, 2022 at 8:12
  • $\begingroup$ you said There is a post here by someone who claims he has achived it ..... you could verify the claim $\endgroup$
    – jsotola
    Feb 9, 2022 at 18:33
  • $\begingroup$ No link, just claim... $\endgroup$
    – Mercury
    Feb 10, 2022 at 19:15
I created a library that does just that, mapping the tegra CPU registers in user space. My lib is here: https://github.com/Rubberazer/JETGPIO it can be called from C or C++
