Is it possible to design and construct a Robot which can solder components using a Soldering iron on printed circuit boards?
If No, What are the limitations?
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityIs it possible to design and construct a Robot which can solder components using a Soldering iron on printed circuit boards?
Yes. There are many soldering robots in existence today. Unfortunately, they don't look very humanoid. They are usually simply gantry style robot arms. They are common on manufacturing lines.
Remember that a robot is just a machine. And machines are designed to do a specific task, usually as efficiently as possible. And this usually means simple, straightforward, and with the fewest extra degrees of freedom. So a humanoid robot doesn't really make sense for this task.
Some quick google searches turn up many examples:
