I don't understand the $\theta$ units. The bicycle model defines $\theta$ as: $$\theta=\theta +\frac{v\cdot\tan\delta}{L}\cdot$$
Where $v$ is the vehicle velocity, $L$ is the wheelbase distance, and $\delta$ is the desired steering angle.
Say I'm driving at $30m/s$ in a vehicle with $L=2.3$, want to steer $50\deg$, and the $\Delta t=0.1$, then $$\theta=0+\frac{30\cdot\tan50\deg}{2.3}\cdot0.1=1.554$$
But what are the units of $\theta$? Radians or Degrees?
Since we need $\theta$ to calculate $x$ for example, with $x=x+v\cos\theta$, when $\theta$ in degrees $x=30\cos 1.554\deg=29.9889$ (slightly changed) or $x=30\cos 1.554\text{ rad}=0.503$ (significantly changed)
The $\theta$ unit is very important but I can't find any reference for it. I guess it should be degrees. Am I right?
