I'm reading "Robot Modeling and Control" by Spong. It seems to me there are mistakes in the manual solutions provided by the authors. I came across the following two questions
enter image description here
In this answer I think there is no $d_3$. It should be zero. In the following question
In my solution $\alpha_2=-90^\circ$ not $90^\circ$ and $\theta_3 = 0^\circ$ not $-90^\circ$. I would love to hear your feedback. Also, if you are instructor, you may need to double check this.
yes you are right in both models.
but add extending length of prismatic joint as it may be able to extend further and add theta to revolute joints
first model
add d1+a1 in the place of d1 and so on
hope it helps
  • $\begingroup$ What DH conversion you're using? What is the table you've provided? $\endgroup$
    – CroCo
    Dec 7, 2021 at 15:44
  • $\begingroup$ i think it is modified dh table. for reference: [ link ](automaticaddison.com/…) $\endgroup$ Dec 8, 2021 at 13:25
