It seems intuitive to me that, in a digital system, a system sampling the error rate "too slowly" will fail to stabilize the system.
Is there a theory/set of metrics/equation I can use to represent this in the frequency or time domain?
i.e.
$$ e(t) : \text{Actual error (not sampled error) with respect to time} \\ e(s) : \text{Laplace or frequency domain representation of error signal} \\ F_s : \text{Rate at which error is sampled} $$
If $e(t)$ has frequency components much higher than $F_s$ (or maybe if $F_s < 2\text{max}[e(s)]$ ), is it possible to properly control the system?
  • $\begingroup$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. $\endgroup$
    – Community Bot
    Nov 19, 2021 at 2:10
If you do not filter out (or filter down) the high frequency components of $e(t)$, they will be "folded back" into the desired spectrum through the process of "aliasing".
Practically speaking, no low-pass filter is ideal, so there will always be high frequency components that get under-sampled and aliased back. You can view these undesired components as a noise contribution at the output of your sampler. Depending on the nature of the high-frequency components, they might just introduce white noise that produces small random errors, or they may introduce a bias that you need to account for.
This paper by Texas Instruments gives a pretty comprehensive treatment of the subject.
  • $\begingroup$ Hey thanks for the effort. What I'm actually interested in is how sampling rate improves controller stability and behavior even with a proper anti-aliasing filter. $\endgroup$ Feb 24, 2022 at 16:51
