I am having trouble getting the robot_pose_ekf package to publish messages. I launch it with this launch file.
<launch>
  <!-- Extended Kalman Filter from robot_pose_ekf Node-->
  <!-- Subscribe: /odom, /imu/data, /vo -->
  <!-- Publish: /robot_pose_ekf/odom_combined -->
  <remap from="/imu_data" to="/imu/data" />
  <node pkg="robot_pose_ekf" type="robot_pose_ekf" name="robot_pose_ekf">
    <param name="output_frame" value="odom"/>
    <param name="base_footprint_frame" value="base_footprint"/>
    <param name="freq" value="30.0"/>
    <param name="sensor_timeout" value="1.0"/>
    <param name="odom_used" value="true"/>
    <param name="imu_used" value="true"/>
    <param name="vo_used" value="false"/>
    <param name="gps_used" value="false"/>
    <param name="debug" value="true"/>
    <param name="self_diagnose" value="true"/>
  </node>
</launch>
But then I get lots of these errors:
[ WARN] [1636570848.059506230]: MSG to TF: Quaternion Not Properly Normalized
[ERROR] [1636570848.059787913]: Covariance specified for measurement on topic imu is zero
[ERROR] [1636570848.060134410]: filter time older than odom message buffer
[ WARN] [1636570848.074015563]: MSG to TF: Quaternion Not Properly Normalized
[ERROR] [1636570848.074583539]: Covariance specified for measurement on topic imu is zero
[ERROR] [1636570848.085433183]: Covariance specified for measurement on topic wheelodom is zero
And I get this output from wtf, which says I'm getting inputs but am not publishing any messages on topic /robot_pose_ekf/odom_combined.
doug@raspi4:~$ rosrun robot_pose_ekf wtf.py looking for node robot_pose_ekf... Input:
  • Odometry sensor
    • is used
    • is active
    • received 12 messages
    • listens to topic /odom
  • IMU sensor
    • is used
    • is active
    • received 152 messages
    • listens to topic /imu/data
  • Visual Odometry sensor
    • is NOT used
    • is NOT active
    • received 0 messages
    • listens to topic
  • GPS sensor
    • is NOT used
    • is NOT active
    • listens to topic Output:
  • Robot pose ekf filter
    • is active
    • sent 0 messages
    • publishes on topics /robot_pose_ekf/odom_combined and /tf
My IMU data is coming from a BNO055 device publishing with code from https://github.com/RoboticArts/ros_imu_bno055.
Any ideas what might be going on?
    $\begingroup$ Hi, can you echo your IMU topic because the error is coming due to the zero covariance matrix of your IMU data. $\endgroup$
    – Franky
    Nov 11, 2021 at 4:03
  • $\begingroup$ ``` doug@raspi4:~$ rostopic echo /imu/data -n1 header: seq: 1 stamp: secs: 1636710493 nsecs: 828954696 frame_id: "imu_link" orientation: x: 95.0 y: 111.0 z: 0.0 w: 16383.0 orientation_covariance: [-1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0] angular_velocity: x: 0.0 y: 0.0 z: 0.0 angular_velocity_covariance: [-1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0] linear_acceleration: x: 0.0 y: -0.03 z: 0.0 linear_acceleration_covariance: [-1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0] --- ``` $\endgroup$
    – Doug
    Nov 12, 2021 at 9:51
