I try to install the tum_ardrone_sim
package in my machine, so I get clone in my workspace this link https://bitbucket.org/theconstructcore/tum_ardrone_sim.git
Finally I try to make it using this command: catkin_make
However I get this error:
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- Generating .msg files for action action_controller/MultiDofFollowJointTrajectory /home/sekmani/catkin_ws/src/tum_ardrone_sim/tum-simulator-indigo/action_controller/action/MultiDofFollowJointTrajectory.action
-- action_controller: 7 messages, 0 services
-- +++ processing catkin package: 'voxel_grid'
-- ==> add_subdirectory(navigation/voxel_grid)
-- +++ processing catkin package: 'costmap_2d'
-- ==> add_subdirectory(navigation/costmap_2d)
-- Boost version: 1.65.1
-- Found the following Boost libraries:
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- costmap_2d: 1 messages, 0 services
-- +++ processing catkin package: 'nav_core'
-- ==> add_subdirectory(navigation/nav_core)
-- +++ processing catkin package: 'base_local_planner'
-- ==> add_subdirectory(navigation/base_local_planner)
-- thread
-- chrono
-- system
-- date_time
-- atomic
-- base_local_planner: 1 messages, 0 services
-- +++ processing catkin package: 'carrot_planner'
-- ==> add_subdirectory(navigation/carrot_planner)
-- +++ processing catkin package: 'clear_costmap_recovery'
-- ==> add_subdirectory(navigation/clear_costmap_recovery)
-- +++ processing catkin package: 'dwa_local_planner'
-- ==> add_subdirectory(navigation/dwa_local_planner)
-- +++ processing catkin package: 'move_slow_and_clear'
-- ==> add_subdirectory(navigation/move_slow_and_clear)
-- thread
-- chrono
-- system
-- date_time
-- atomic
-- +++ processing catkin package: 'navfn'
-- ==> add_subdirectory(navigation/navfn)
-- navfn: 0 messages, 2 services
-- NAVFN_HAVE_FLTK: 1, NETPBM:
-- FLTK orf NETPBM not found: cannot build navtest
-- +++ processing catkin package: 'global_planner'
-- ==> add_subdirectory(navigation/global_planner)
-- +++ processing catkin package: 'rotate_recovery'
-- ==> add_subdirectory(navigation/rotate_recovery)
-- +++ processing catkin package: 'move_base'
-- ==> add_subdirectory(navigation/move_base)
-- +++ processing catkin package: 'turtlebot3_description'
-- ==> add_subdirectory(turtlebot3/turtlebot3_description)
See also "/home/sekmani/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/sekmani/catkin_ws/build/CMakeFiles/CMakeError.log".
Makefile:7194: recipe for target 'cmake_check_build_system' failed
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
I try to solve it, so I run this command:
rosdep install --from-paths /home/sekmani/catkin_ws/src --ignore-src
But also I get this error:
ERROR: the following packages/stacks could not have their rosdep keys resolved
to system dependencies:
amcl: [python3-pykdl] defined as "not available" for OS version [bionic]
I am using ROS melodic and Ubuntu 18.
