Is there another way to generate a collada model to work with openrave other than converting an URDF file with ROS' collada_urdf software?
The problem I'm encountering is with the setup needed to use ROS' program (setting up the ros distro and catkin, ecc..).
Since I've drawn the robot in SolidWorks is there a simpler way to generate the needed collada model?
