With the announcement of the iRobot Create3 "with ROS2 support", and to get a head start playing with it, iRobot has some create3 GitHub repos:
- https://github.com/iRobotEducation/create3_sim
- https://github.com/iRobotEducation/create3_examples and apparently a dependency on:
- https://github.com/iRobotEducation/irobot_create_msgs
I have started a "Create3 ROS2 Controller" with a RaspberryPi3B running ROS2 Galactic over 64-bit Ubuntu 20.04 Server.
Since this is a headless, no desktop install, I have not installed the create3_sim repo.
Where should I put irobot_create_msgs and how do I build it?
My tree:
$ tree -L 2
├── create3ros
│ ├── create3_examples_ws
│ ├── create3_ws
This is the error:
ubuntu@CREATE3:~/create3ros/create3_examples_ws$ colcon build
Starting >>> create3_examples_msgs
Starting >>> create3_examples_py
Finished <<< create3_examples_py [5.42s]
[Processing: create3_examples_msgs]
Finished <<< create3_examples_msgs [49.4s]
Starting >>> create3_coverage
--- stderr: create3_coverage
CMake Error at CMakeLists.txt:22 (find_package):
By not providing "Findirobot_create_msgs.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"irobot_create_msgs", but CMake did not find one.
Could not find a package configuration file provided by
"irobot_create_msgs" with any of the following names:
irobot_create_msgsConfig.cmake
irobot_create_msgs-config.cmake
Add the installation prefix of "irobot_create_msgs" to CMAKE_PREFIX_PATH or
set "irobot_create_msgs_DIR" to a directory containing one of the above
files. If "irobot_create_msgs" provides a separate development package or
SDK, be sure it has been installed.
Failed <<< create3_coverage [7.51s, exited with code 1]
Summary: 2 packages finished [58.1s]
1 package failed: create3_coverage
1 package had stderr output: create3_coverage
