I`m doing some underwater UUV Gazebo simulation and would like to use the
hector_pose_estimation
package to fuse IMU and Fluid pressure sensors input for pose estimation.
So my Pressure Sensor has sensor_msgs/FluidPressure
but the package wants pressure_height (geometry_msgs/PointStamped)
as input. So I created a ROS C++ node to republish sensor_msgs/FluidPressure as the geometry_msgs/PointStamped. The code compiled with no error, but when run it I got error. Firstly, this is the code
#include "ros/ros.h"
#include "sensor_msgs/FluidPressure.h"
#include <std_msgs/Float64.h>
#include <geometry_msgs/PointStamped.h>
double current_pressure;
double depth;
ros::Publisher pub_ ;
geometry_msgs::PointStamped output;
void pressureCallback(const sensor_msgs::FluidPressure::ConstPtr& msg)
current_pressure= msg->fluid_pressure;
depth=current_pressure / (997.04*9.8);
//geometry_msgs::PointStamped::ConstPtr& output;
output.point.z = depth;
//positions_pub.publish(output_msg);
//output.z=depth;
pub_.publish(output);
ros::init(argc, argv, "pressure_republisher");
ros::NodeHandle n;
ros::Subscriber sub = n.subscribe("/rexrov2/pressure", 10, pressureCallback);
ros::Publisher pub_ = n.advertise<geometry_msgs::PointStamped>("/pressure_height", 50);
ros::spin();
return 0;
And when run it this it the ERROR:
[FATAL] [1633258406.824329181, 173.610000000]: ASSERTION FAILED
file = /opt/ros/melodic/include/ros/publisher.h
line = 106
cond = false
message =
[FATAL] [1633258406.826511155, 173.612000000]: Call to publish() on an invalid Publisher
[FATAL] [1633258406.826551511, 173.612000000]:
Any help?
