Im using thisrobot_lokalization robot_localization package for the linear velocity. As only sensor input in my case is IMU. I configure the parameters and set the frames as follow
map_frame: map
odom_frame: odom
base_link_frame: /thrbot/base_link
world_frame: odom
The launch file is the following one
<launch>
  <node pkg="robot_localization" type="ekf_localization_node" name="ekf_se" clear_params="true">
    <rosparam command="load" file="$(find robot_localization)/params/ekf_template.yaml" />
    <param name="odom_used" value="false"/>
  </node>
  <node pkg="tf" type="static_transform_publisher" name="base_link_to_imu" args="0 0 0 0 0 0  /thrbot/base_link /thrbot/imu_link  100" />
</launch>
The robot base_link frame is thrbot/base_link the IMU is thrbot/imu_link
Here is the photo of the TF without using the packageNormal TF of the Robot and the world . But when using the package my TF is broken as can see from the photo here broken TF. Any help how to fix the TF and correctly use the package with IMU as only sensor input?
To fix the TF i change the configure the parameters in ekf_template.yaml as follow
odom_frame: odom
base_link_frame: /thrbot/base_footprint
world_frame: odom
and the launch file to follow
<launch>
    <param name="frame_id" value="odom"/>
  </node>
  <node pkg="tf" type="static_transform_publisher" name="base_link_to_odom" args="0 0 0 0 0 0 /odom /thrbot/base_footprint 100" />
</launch>
Now the TF looks good as can see Fixed TF. Than following parameters are configure in ekf_template.yaml:
imu0: /thrbot/imu
imu0_config: [false, false, false,
              true, true, true,
              true,  true,  true,
              true,  true,  true]
imu0_remove_gravitational_acceleration: true
imu0_nodelay: false
imu0_differential: false
imu0_relative: true
imu0_queue_size: 5
imu0_pose_rejection_threshold: 0.8
imu0_twist_rejection_threshold: 0.8
imu0_linear_acceleration_rejection_threshold: 0.8
My question is now as that correct configuration for underwater UUV to get linear velocity?
Based on your configuration, you are trying to create map -> odom -> /thrbot/base_link. But you do not have a map frame. Looking at your oroginal TF, you should instead create world -> odom -> base_footprint.
I think your configuration should be:
odom_frame: odom
world_frame: world
EDIT: as pointed out,
world_frame: odom
19
  • $\begingroup$ Ok. So what should I put in map_frame: ? just leave it empty? $\endgroup$
    – bob
    Sep 27, 2021 at 5:36
  • $\begingroup$ with odom_frame: odom base_link_frame: /thrbot/base_footprint world_frame: world I got ERROR Odometry message frame_id was world, expected map or odom . I think in the launch file need to specify parent and child frame correctly. Is this static transform in the above launch file ok? ` <node pkg="tf" type="static_transform_publisher" name="base_link_to_imu" args="0 0 0 0 0 0 /thrbot/base_link /thrbot/imu_link 100" /> ` $\endgroup$
    – bob
    Sep 27, 2021 at 6:19
  • $\begingroup$ also in the ekf_template.yaml Im not sure about odom parameters settings such as; odom0: example/odom . is that correct? what should i put in odom parameters? $\endgroup$
    – bob
    Sep 27, 2021 at 6:48
  • $\begingroup$ ok. Fix the TF . I update the question with the new settings and launch file, but have several doubts. . How to be sure that everything is in local frame and how to assure that the velocity is the real velocity of the robot? ( i know there will be error regarding the integration and will accumulate with time) but I like to know that with the parameters settings Im estimation the velocity of the robot and not something else. Please can you help with that? $\endgroup$
    – bob
    Sep 27, 2021 at 12:54
  • $\begingroup$ Since you do not have a map, you can leave the map_frame empty, or just skip that tag. You are correct, the world_frame should be odom. My bad! In your example, you only have an IMU right? If so, you should not populate odom0. $\endgroup$ Sep 27, 2021 at 14:12
