I am using ROS melodic,turtlebot 2 on Ubuntu 18.04.
The idea is to create an environment consisting of lines as a path (slightly curved), and to program the turtlebot to follow the lines. Basically, a line following bot.
The idea is to click photos using the camera mounted on the turtlebot,process them to segment out the path which needs to be followed, and then control the bot's orientation, by using PID to control the angular velocity, so that it moves along the path.
I have created a program called take_photo_mod.py, which successfully keeps clicking photos and saving them as image.jpg, at a frequency that can be controlled.
 #!/usr/bin/env python
    from __future__ import print_function
    import sys
    import rospy
    import cv2
    from sensor_msgs.msg import Image
    from cv_bridge import CvBridge, CvBridgeError
    class TakePhoto:
        def __init__(self):
            self.bridge = CvBridge()
            self.image_received = False
            img_topic = "/camera/rgb/image_raw"
            self.image_sub = rospy.Subscriber(img_topic, Image, self.callback)
            rospy.sleep(1)
        def callback(self, data):
            try:
                cv_image = self.bridge.imgmsg_to_cv2(data, "bgr8")
            except CvBridgeError as e:
                print(e)
            self.image_received = True
            self.image = cv_image
        def take_picture(self, img_title):
            if self.image_received:
                cv2.imwrite(img_title, self.image)
                rospy.loginfo("received")
                return True
            else:
                return False
    if __name__ == '__main__':
        rospy.init_node('take_photo', anonymous=False)
        camera = TakePhoto()
            img_title = rospy.get_param('~image_title', 'image'.jpg')
            if camera.take_picture(img_title):
                rospy.loginfo("Saved image " + img_title)
            else:
                rospy.loginfo("No images received")
            rospy.sleep(1)
As for the next part, I plan to create a program go_forward.py, which incorporates two things:
Part 1. The openCV aspect: processing the image clicked to segment out the path. I have successfully managed to do this:
import cv2
import numpy as np
import math as m
def contor(lst):
    if len(lst)>1:
        m = list()
        for i in lst:
            for j in i:
                m.append(j[0])
        m = np.array(m)
    else:
        m=np.array([[w//2,h-150],[w//2,h-40]])
    print("m=",m)
    m = m[m[:, 1].argsort()]
    return m
def aver(i, p):
    a = p[i]
    y = int(np.mean([a[:, 0]]))
    x = int(np.mean([a[:, 1]]))
    return (y, x)
def extract(frame):
    theta=0
    phi=0
    print("h,w =",h,w)
    hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
    lb = np.array([0, 0, 0])
    ub = np.array([255, 50, 160])
    mask = cv2.inRange(hsv, lb, ub)
    res = cv2.bitwise_and(frame, frame, mask=mask)
     res2 = cv2.cvtColor(res, cv2.COLOR_BGR2GRAY)
        ret, thres = cv2.threshold(res2, 100, 255, cv2.THRESH_BINARY)
        countours, hierarchy = cv2.findContours(thres, cv2.RETR_TREE, cv2.CHAIN_APPROX_NONE)
        cv2.drawContours(frame, countours, -1, (255, 0, 255), 3)
        points = contor(countours)
        i = np.where((points[:, 1] > h - 80) & (points[:, 1] < h))
        #print('i1', len(i[0]))
        if len(i[0]) > 0:
            end = aver(i, points) #coordinates (x2,y2)
        else:
            end = (w // 2, h)
        i = np.where((points[:, 1] > h - 190) & (points[:, 1] < h - 110))
        #print('i2', len(i[0]))
        if len(i[0]) > 0:
            strt = aver(i, points) #coordinates (x1,y1)
        else:
            strt = (w // 2, h - 200)
        frame=cv2.line(frame,strt,end,(255,0,0),9)
        cv2.imshow("aa",frame)
        cv2.waitKey()
        cv2.destroyAllWindows()
        if (strt[0] - end[0]) == 0:
            phi=m.pi/2 #angle with horizontal
            theta=0 #angle with vertical
        else:
            slope = (strt[1] - end[1]) / (end[0] - strt[0])
            phi=m.atan2(slope) #angle with horizontal
            theta= (m.pi/2) - phi #angle with vertical
        return theta
    frame=cv2.imread("image.jpg",1)
    h, w, _ = frame.shape
    i,d=0,0
    error=extract(frame)
    print(error)
image.jpg ( which I was using for testing the openCV aspect. When take_photo_mod.py runs , image.jpg will keep changing at the frequency with which the bot will take photos)
enter image description here
This draws a line that approximately gives the direction along the path. Further, this calculates the angle with the angle with the vertical.
Part 2. PID aspect: This is the part with which I am struggling. The camera is mounted on the bot, so whatever we are calculating on the image is in the bot's frame,and the orientation of the bot in the bot's frame is along the vertical. Hence the angle which we calculate with the vertical acts as the "error" term: the angle by which the bot should turn to be along the path. Now, I think it's the angular velocity which will serve as the control signal.
I already have a script that just makes the bot go forward till its terminated.It had angular velocity fixed at 0. So,the program "goforward.py" will basically be the combination of the openCV aspect ,and tweaking the "simply go forward" script to use PID to set it's angular velocity (instead of it being fixed at 0). Then, the two programs(nodes) take_photo_mod.py and goforward.py will be launched together using a launch file.
What I tried for goforward.py:
import rospy
import cv2
import numpy as np
import math as m
from geometry_msgs.msg import Twist
#openCV aspect
def contor(lst):
    if len(lst)>1:
        m = list()
        for i in lst:
            for j in i:
                m.append(j[0])
        m = np.array(m)
    else:
    #print("m=",m)
    return m
def aver(i, p):
    a = p[i]
    return (y, x)
def extract(frame):
    #print(h,w)
    countours, hierarchy = cv2.findContours(thres, cv2.RETR_TREE, cv2.CHAIN_APPROX_SIMPLE)
    if len(i[0]) > 0:
    else:
        end = (w // 2, h)
    if len(i[0]) > 0:
    else:
    if (strt[0]-end[0]) == 0:
        theta = 0 #angle with vertical
    else:
    return theta
#PID
def PID (kp,ki,kd,dt,error):
#making the bot move
class GoForward():
    def _init_(self):
        rospy.init_node('GoForward', anonymous=False)
        rospy.loginfo("To stop TurtleBot CTRL + C")
        rospy.on_shutdown(self.shutdown)
        self.cmd_vel = rospy.Publisher('cmd_vel_mux/input/navi', Twist, queue_size=10)
        r = rospy.Rate(10)
        move_cmd = Twist()
        move_cmd.linear.x = 0.2
        move_cmd.angular.z = 0
            w=0
            kp=0.15
            ki=0.02
            kd=0.02
            dt=0.01
            w= PID(kp,ki,kd,dt,error)
            velocity_control=0.5 #when the bot is turning, its velocity should be slowed down.
            move_cmd.linear.x = 0.2-(veclocity_control *abs(w))
            move_cmd.angular.z = -w  #-sign because we are controlling angular velocity in -z direction (clockwise),if the error is positive, and vice versa
            self.cmd_vel.publish(move_cmd)
            r.sleep()
    def shutdown(self):
        rospy.loginfo("Stop TurtleBot")
        self.cmd_vel.publish(Twist())
        rospy.sleep(1)
if _name_ == '_main_':
    try:
        GoForward()
    except:
        rospy.loginfo("GoForward node terminated.")
The problem I'm having is to implement the PID part properly. How exactly should I approach writing the PID (...) function?
Something I tried: (pseudocode):
def pid_controller (kp,ki,kd,dt,error):
    e_prev = error
    e_sum = 0
while  :
    e=?
    e_sum = e_sum + e *dt
    dedt = ( e - e_prev ) / dt
    w = kp * e + ki * e_sum + kd* dedt
    e_prev = e
return w
I've got it in bits and pieces but I still don't know how the full thing should work exactly.... for instance when should the loop terminate? What exactly should I have in place of e and e_prev?
  • $\begingroup$ Welcome to Robotics, satan 29. Could you please explain more about your PID problem? What are you having trouble with? Typically you have a reference and feedback, then take the difference as the reference error, and that's what is used by the PID controller. Are you having issues with getting the reference and feedback, or tuning, or general implementation? $\endgroup$
    – Chuck
    Sep 8, 2021 at 13:58
  • $\begingroup$ General implementation. Ill edit it slightly to add something I tried $\endgroup$
    – satan 29
    Sep 8, 2021 at 16:58
  • $\begingroup$ I have edited it. By the way, the reference error is "theta" calculated by the openCV part of the code. $\endgroup$
    – satan 29
    Sep 8, 2021 at 17:42
You're defining
... the error is your e. The alternative would be to define
def pid_controller (kp,ki,kd,dt,theta_reference,theta_feedback)
and have
error = theta_reference - theta_feedback
e = error
  • $\begingroup$ what should I have as e_prev then ? and when does the loop terminate? $\endgroup$
    – satan 29
    Sep 8, 2021 at 18:09
  • 2
    $\begingroup$ @satan 29 - e_prev is the previous error, so just set e_prev = error any time after you're done using e_prev for the current call (i.e. any time after defining dedt). The PID function itself doesn't loop, your program should be looping and calling the PID function. e_prev and e_sum will need to be static or persistent (can't remember what the correct term is in python) to not get reset between function calls. Your main code should check for a reference update, poll for feedback, calculate reference error, call the PID controller, then send the PID output to the motor/drive system, then loop. $\endgroup$
    – Chuck
    Sep 9, 2021 at 1:01
