I have raspberry pi in a robot but it seems sdcard is not reliable at all.
What are affordable options that could be considered reliable? Pi+USB Flash, Pi+USB SSD, Pi compute module with eMMC, BeegleBoard with eMMC?
May be there is some reliable SD card brand or USB_Flash?
I would say my budget is up to $350 and I need linux computer with performance of Pi3 and 2-4 USB ports + IO
It seems to me right now that Pi+USB_Good_Brand_SSD is most reliable option. But may be I miss something.
    $\begingroup$ probably all of the ones you listed $\endgroup$
    – jsotola
    Aug 1, 2021 at 23:09
  • $\begingroup$ What do you mean by "not reliable"? I have been using pi for a long time but never had a problem with SD unless I cut the power while the pi is writing a file to SD. Pi has multiple background processes that writes files to SD. So if you cut the power without parking it, it will be corrupted. $\endgroup$ Aug 2, 2021 at 2:51
  • $\begingroup$ @C.OPark I had lots of dead sdcards: Samsung, SanDisk and chinese no name. May be some of brand sdcards are fake. But I have no idea how to ensure I will get real brand sdcard. It seems USB Flash is often more reliable than sdcard and good brand SSD is much more reliable than the rest. $\endgroup$
    – Artem
    Aug 2, 2021 at 17:39
  • $\begingroup$ I would recommend trying a read-only mode if possible. Another solution is using a high endurance sd card which is originally dedicated to a dashcam. $\endgroup$ Aug 3, 2021 at 5:02
The Argon One case has a USB 3.0 M.2 adapter for the raspberry pi 4. So, you could use an SSD instead of an SD card, if that is where you're having issues.
https://www.argon40.com/argon-one-m-2-case-for-raspberry-pi-4.html
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
