I have found several sources that state that a Joint space trajectory model is not capable of dealing with obstacles in the manipulator workspace. These sources include:
slide 10 of "Manipulator Trajectory Planning":
URL: https://cw.fel.cvut.cz/old/_media/courses/a3m33iro/080manipulatortrajectoryplanning.pdf
and also Mathworks in their presentation on Trajectory Planning for Robot Manipulators on Youtube at timestamp 3:16.
URL: https://www.youtube.com/watch?v=Fd7wjZDoh7g&ab_channel=MATLAB.
The problem I am facing is that these sources do not explain why joint space models can not deal with obstacles.
Is there somebody here that can shed some light on this?
The main difference between task space control and joint space control are :
Joint space : You know start and last position of joint configuration from IK(Inverse kinematic), and interpolate it
Task space : You know start and last position of end-effector, then interpolate it and IK every point in path to get joint configuration for every point in path.
Obstacle are known in cartesian space (x,y,z, and orientation). The other component we know in cartesian space is end-effector. Obstacle avoidance only able to be performed on task space control because on task space control we have information position and orientation of end-effector which may collide with obstacle, thus we can plan the path of end-effector. While in joint space we didnt have that information because we didnt plan the path of end-effector(only take the first and last position and orientation of end-effector).
  • $\begingroup$ You seem very knowledgeable on the subject of joint spaces, Could you help me with another question? Why are Joint Space trajectories so curvy compared to Task Space trajectories. The image in this question shows the Task Space vs Joint Space trajectories. robotics.stackexchange.com/questions/22626/… $\endgroup$
    – user463102
    Commented Sep 14, 2021 at 11:35
