I'm currently developing a pygame based go to goal behavior. I approached the goal by Euclidean distance and vectorized mathematics. Here is the code
def move(roborect,i):
no_plants=len(test_x)
if(no_plants>i):
    dx = 8*test_x[i]-roborect.x
    dy = test_y[i]-roborect.y
    distance = math.sqrt(dx*dx + dy*dy)
    print(distance)
    if distance > 70:
        vx = dx * 2/ distance
        vy = dy * 2 / distance
    #print(vx,vy)
        #print(roborect.x,roborect.y)
        roborect.x += vx
        roborect.y += vy
    else:
        return 1
But I could not understand to approach the orientation of the robot towards to goal.Please help.
What have you tried? This seems like it should simply be the inverse tangent of dy/dx.
  • $\begingroup$ I have tried try: grad=(test_x[i]-roborect.y)/(test_y[i]-roborect.x) angle=math.degrees(math.atan(grad)) print(angle) except: pass $\endgroup$ Jun 14 at 1:12
  • $\begingroup$ Theres is possibility grad = infinitie.. so in the exception you should handle that math error.. except : angle = 90 $\endgroup$
    – Albert H M
    Jun 14 at 1:20
  • $\begingroup$ Try atan2(dy, dx). $\endgroup$
    – SteveO
    Jun 14 at 1:25
  • $\begingroup$ Yes, I used dx/dy instead of dy/dx $\endgroup$ Jun 14 at 1:44
