I'm building a quadcopter. It will be controlled by a Beaglebone black with several Sensors and a cam.
I new to the quadcopter stuff, therefore it would be nice if someone could have a look at my setup before I buy the parts.
This sums up to ~ 2kg. Giving me still some room for about 700g payload.
What do you think? Did I miss something important? Better ideas for some parts?
  • $\begingroup$ When you calculated the 700g payload how much margin did you leave? $\endgroup$
    – Guy Sirton
    Jan 2, 2014 at 20:39
  • $\begingroup$ @GuySirton. I did change the frame so it will be now around 2.1 kg. with Payload. The max. thrusth should be around 4.3 kg $\endgroup$
    – magu_
    Jan 4, 2014 at 13:39
Looks good to me. You also need:
  1. propellers
  2. power distribution board which keeps thing more organised until you make your own PCB.
  3. A Li-Po battery charger with a compatible connector.
  4. Spare parts. (Many propellers, and few motors and ESCs)
Also visit xcoptercalc to 'simulate' the parts.
Be careful with the motors since there are some openings at the bottom making it easy for small metal dust to enter the motor. If metallic dust enters the motor, it is almost impossible to detach it from those permanent magnets.
  • $\begingroup$ Thank you for your answer. I already did some ecalc calculations which seemed to be ok. I'm not sure what you meant with the motor point. I didn't find any brush less motors which are sealed. You mean the motor can get stuck or that the motor cannot be detached from its mounting anymore? $\endgroup$
    – magu_
    Jan 4, 2014 at 13:43
  • $\begingroup$ If metall dust enters, the motor will run but with some friction. The amount of friction is proportional to the size of metall dust. You shouldn't really worry too much about it if you are not going to cut the shafts or work in a metal workshop. $\endgroup$
    – nFu9DT
    Jan 4, 2014 at 14:10
  • $\begingroup$ Well cutting the shaft is gonna be difficult with that version of the motor... Thank you for you're explenation. $\endgroup$
    – magu_
    Jan 4, 2014 at 14:22
You should have a prop balancer like this which will ensure that propellers are well balanced. Also you should have a Lipo alarm like this which can warn you when you are low on battery during fight.
5
  • $\begingroup$ Thank you for the tip for the balancer. I'll defenetly have a look. For the battery. Do you think it is enough to look at the overall voltage of the battery (the BBB has a analog in) or should I survey all the cells induvidually? $\endgroup$
    – magu_
    Jan 5, 2014 at 12:01
  • $\begingroup$ It is always good to monitor all the cells in lipo as there is always a chance of unbalance of voltage between cells. If you are going to use analog in of BBB then make sure it has proper current protection as lipo can supply lots of current. $\endgroup$
    – nikhil
    Jan 5, 2014 at 16:24
  • $\begingroup$ Hm, I would have thought about a simple voltage splitter (2 Resistors) - maybe together with a shotky diode in order to protect the BBB. Shouldn't this be enough? $\endgroup$
    – magu_
    Jan 6, 2014 at 7:13
  • $\begingroup$ I use this sensor which gives me analog voltage and current input to 3.3V. And controller is also protected as I am not connecting lipo directly to controller. $\endgroup$
    – nikhil
    Jan 6, 2014 at 8:17
  • $\begingroup$ This is a nice tool. I'll put it onto my shoping list, I wasn't really thinking about a ampere meter till now. $\endgroup$
    – magu_
    Jan 6, 2014 at 8:35
