I'm going through an online course on Coursera for Reinforcement Learning that makes use of RLGlue. I want to try to run and adapt the code locally, but am having issues using RLGlue, and not sure why.
I was going through an Reinforcement Learning Course and wanted to try running the code locally. I installed RLGlue with pip install rlglue
from here
But then when trying to run the code:
from rlglue.rl_glue import RLGlue
import main_agent
import ten_arm_env
import test_env
Received this error message: ModuleNotFoundError: No module named 'rlglue.rl_glue'
I also attempted to install it from here that supports the course, and with
pip install git+https://github.com/andnp/[email protected]
but that didn't work either.
Any idea on how to fix that to import the module and run the code?
