I am beginner in the robotics space and I am trying to apply inverse kinematics to robot leg that has 4 degrees of freedom. I do not know how to think about solving these problems, so any guidance would be greatly appreciated!
The legs are from this system and I am working to understand only one currently (this may be the wrong approach): https://www.robotshop.com/en/lynxmotion-t-hex-4dof-hexapod-robot-kit-hardware-only.html
My first question is, is inverse kinematics the correct approach? To me it seems to be since I want to determine the angles for the servos based on the foot position and trajectory. If anyone has any recommendations with respect to this I would greatly appreciate it so that I know am not headed down the right path. That being said, I am struggling to find solutions to problems of this sort. It seems as though 4 DoF is more challenging and is often not solved analytically. I would still like to solve this analytically, but I have moved on to try out numerical solutions.
In MATLAB, I have worked through several examples and I have tried to transition them to the case of this system. I have attached my code so far. Currently, I am struggling with applying joint constraints, getting the configuration that is more physical, and getting a useable solution from this approach. So my questions to this are:
  1. Is this a valid approach to finding the solution to inverse kinematics of this system?
    • As in, if I manage to get this to work, is the solution useable? I may be picturing this wrong, but I foresee getting a sequence of servo angles that will correspond to the trajectory. If I get these servo angles (and the joint constraints, lengths, etc. are all physically accurate) will I be able to give the leg the sequence? If this is even a valid approach, I have some MATLAB questions to follow.
  2. Will this approach transition well to when there are more legs (i.e. the complete robot with 6 legs)?
  3. How do joint constraints work in the robotics toolbox?
    • It seems like rotation is right-handed with respect to the axis of rotation. In addition, when a positive angle is applied, it seems to rotate the rigidbody below the local coordinate system of the joint. However, there are joint constraints to the servos and when I try to apply these, the IK solver that I setup fails to follow the defined trajectory and will give errors saying that the joint angle is outside of the constraints set, even when I make sure that they are valid ranges. I have not been able to find useful documentation on this.
  4. If I get the joint constraints set correctly, will the solution be in the correct configuration?
    • Should I consider other constraints to apply?
    • Is the invverseKinematics from MATLAB what I need or should I be trying generalizedInverseKinematics?
  5. Currently, I defined some random arc for the trajectory. Should I consider something else for the walk of a hexapedal robot?
I am open to any suggestions since it is clear that I do not have any direction. Please let me know if more information is needed and I will edit the post. Physical dimensions of the robot are included in the code. The height of base is arbitrary currently. I have tried to comment the code heavily so that it is easy to understand. Lastly, here are 4 images showing the current results of the MATLAB simulation. blue lines are the body segments and the black ark is the trajectory.
XY and YZ Perspective Labeled 3D System
Code:
% Robot_Advanced_Real.m
% Copied from matlab and adapted for my scenario.
% Creates robot, uses IK to calculate positions, Creates animation
% Initialize MATLAB
clear all;
close all;
clc;
tic;
%% Building Robot
% Start with Blank RigidTreeBody Model
robot = rigidBodyTree('DataFormat','column','MaxNumBodies',5);
% Specify Arm Lengths of the Robot Arm. Units: [mm]
L1 = 28.45;
L2 = 75.41;
L3 = 70.02;
L4 = 87.14;
% Height of robot body off of Ground
G = 100;
% Add first body with joint. Set as robot base.
body = rigidBody('link1');
joint1 = rigidBodyJoint('joint1', 'revolute');
setFixedTransform(joint1,trvec2tform([0 0 G]));
joint1.JointAxis = [0 0 1];
joint1.HomePosition = pi/6;
% joint.PositionLimits = [0, pi];
body.Joint = joint1;
addBody(robot, body, 'base');
% Add second body with joint. Attach to First
body = rigidBody('link2');
joint2 = rigidBodyJoint('joint2','revolute');
setFixedTransform(joint2, trvec2tform([L1,0,0]));
joint2.JointAxis = [0 1 0];
joint2.HomePosition = pi/6;
body.Joint = joint2;
addBody(robot, body, 'link1');
% Add third body with joint. Attach to second
body = rigidBody('link3');
joint3 = rigidBodyJoint('joint3','revolute');
setFixedTransform(joint3, trvec2tform([L2,0,0]));
joint3.JointAxis = [0 1 0];
joint3.HomePosition = pi/6;
body.Joint = joint3;
addBody(robot, body, 'link2');
% Add fourth body with joint. Attach to third
body = rigidBody('link4');
joint4 = rigidBodyJoint('joint4','revolute');
setFixedTransform(joint4, trvec2tform([L3,0,0]));
joint4.JointAxis = [0 1 0];
joint4.HomePosition = pi/6;
body.Joint = joint4;
addBody(robot, body, 'link3');
% Add End Effector with Fixed Joint. Attach to final body.
body = rigidBody('tool');
joint = rigidBodyJoint('fix1','fixed');
setFixedTransform(joint, trvec2tform([L4, 0, 0]));
body.Joint = joint;
addBody(robot, body, 'link4');
% View Robot Input details to review setup
showdetails(robot);
%% Define Trajectory
% Define series of [x y z] for arc step.
% Define parameters of the arc.
xCenter = 0;
yCenter = 120;
zCenter = 0;
xRadius = 70;
yRadius = 20;
zRadius = 20;
% Define the angle theta as going from 30 to 150 degrees in 100 steps.
theta = linspace(30, 150, 100);
% Define x and y using "Degrees" version of sin and cos.
x = (xRadius * cosd(theta) + xCenter)';
y = (yRadius * sind(theta) + yCenter)';
z = (zRadius * sind(theta) + zCenter)';
% Points around circle
% points = center + [x y z];
points = [x y z];
count  = length(x);
% Check
% plot3(points(:,1),points(:,2),points(:,3))
plot3(x,y,z)
hold on
plot3(points(:,1),points(:,2),points(:,3),'k')
xlabel('x')
ylabel('y')
zlabel('z')
%% Inverse Kinematics
% Use IK object to find a solution to the joint configurations that achieve
% end effector coordinates along ttrajectory
% Pre-allocate configuration solutions as a matrix, qs
q0 = homeConfiguration(robot);
ndof = length(q0);
qs = zeros(count, ndof);
% create the IK Solver.
ik = inverseKinematics('RigidBodyTree', robot);
% Use desired weights for solution (First three are orientation, last three are translation)
% Since it is a 4-DOF robot with only one revolute joint in Z we do not
% put a weight on Z rotation; otherwise it limits the solution space
% weights = [0, 0, 0, 1, 1, 0];
weights = [0.1, 0.1, 0, 1, 1, 1];
endEffector = 'tool';
% Loop through the trajectory and store the configurations. IK is used to
% give joint configurations.
qInitial = q0; % Use home configuration as the initial guess
for i = 1:count
    % Solve for the configuration satisfying the desired end effector
    % position
    point = points(i,:);
    qSol = ik(endEffector,trvec2tform(point),weights,qInitial);
    % Store the configuration
    qs(i,:) = qSol;
    % Start from prior solution
    qInitial = qSol;
end
%% Animate Solution
% Show first configuration. Show trajectory.
figure
show(robot,qs(1,:)');
ax = gca;
ax.Projection = 'orthographic';
hold on
view([-37.5 30])
% Set up animation. Show robot in each configuration on trajectory
framesPerSecond = 7;
r = rateControl(framesPerSecond);
for i = 1:count
    show(robot,qs(i,:)','PreservePlot',false);
    drawnow
    waitfor(r);
end
toc
