I have a Micro Magician v2 micro controller. It has a A3906 Dual FET “H” bridge motor driver built in.
In the manual it states "Electronic braking is possible by driving both inputs high."
My first question is, what is the purpose of these brakes? If I set the left/right motor speed to 0, the robot stops immediately anyway. What advantage is there to using these brakes, or am I taking the word "brake" too literally?
My second question is, the driver has "motor stall flags that are normally held high by pullup resistors and will go low when a motor draws more than the 910mA current limit. Connect these to spare digital inputs so your program will know if your robot gets stuck." But when my robot hits a wall, the wheels just keep on spinning (slipping if you will), I take it these stall flags can be used on a rough surface where the wheels have more friction?
