I am using a raspberry pi 4 connecting to a PCA9685 and following the instruction on the donkeycar doc site (the link can be found below). I am at the step "fine tuning calibration." When I run "python manage.py drive" the steering works using my keyboard controls but the throttle is not causing any movement with the keys. I know that the throttle is not broken because the wheels turn when I do the calibration of the throttle. How do I solve this?
https://docs.donkeycar.com/guide/calibrate/
There can be a few explanations for this:
  1. Does your motor controller (ESC) have an on-off switch? If so, try flipping that
  2. Some ESCs need to "arm". Try going to full throttle and back and see if that makes a difference
  3. I'm assuming you have your battery plugged in ;-)
  4. Try reversing the direction in the myconfig.py file
  • $\begingroup$ Hi Chris! I have the switch on so that is not the problem and I do have the battery plugged in! When I reach about .6 throttle on local host the car starts to beep, should I push past that point? $\endgroup$ – Megan Jones May 8 at 0:29
  • $\begingroup$ Looks like your calibration value is not correct. Try increasing THROTTLE_STOPPED_PWM and THROTTLE_FORWARD_PWM. When you have the right THROTTLE_STOPPED_PWM value, running python manager.py drive will produce a beep sound from the ESC $\endgroup$ – Jonathan Tse May 8 at 0:40
  • $\begingroup$ when I was calibrating, 370 was when the car beeped! what should I be trying to change it to? $\endgroup$ – Megan Jones May 8 at 0:46
