I try to understand jacobian for robot control. I want to precisely understand how to build that matrix. Can someone advice me course which explain how to create that matrix on a simple sample?
An other question about that matrix, I read that this matrix had to be process every step. Is it true?
Jacobian matrix is used to describe the relationship between the configuration space (space of joint angles) and the task space (space of end-effector pose) as follows:
$\textbf{$\dot{p}$} = \textbf{J(q)}\textbf{$\dot{q}$}$,
where $\textbf{J(q)}$ is the Jacobian matrix, $\textbf{p}$ and $\textbf{q}$ are vectors represented for the end-effector pose and joint angles, respectively.
Several tutorials:
https://realitybytes.blog/2017/06/20/forward-and-inverse-kinematics-jacobians-and-differential-motion/
https://automaticaddison.com/the-ultimate-guide-to-jacobian-matrices-for-robotics/
http://www8.tfe.umu.se/courses/elektro/RobotControl/Lecture07_5EL158.pdf
You can do further searching with keywords: Denavit–Hartenberg, kinematics modeling, etc.
  • $\begingroup$ "Jacobian matrix is used to describe the relationship between the configuration space (joint angles) and the task space (end-effector pose)": that's not correct as the relation needs to be intended in the differential manner, hence relating the joint velocities and the end-effector velocities. Please, amend your answer. $\endgroup$ Apr 22, 2021 at 18:10
  • 2
    $\begingroup$ thanks, just added extra terms to make it clear. $\endgroup$
    – Karim
    Apr 23, 2021 at 6:46
