I'm having a problem with controlling my BLDC motor when starting up and when running in low rpm. I have a custom board to measure rotation of the motor using an optical sensor and send servo pwm commands to an esc. The problem is, that I can't start the motor smoothly. When I slowly increase the control signal, it starts stuttering and then jumps directly up to about 1500rpm.
Is there a way to improve this situation without using a sensored motor/esc combo?
