We are planning to recalibrate ABB IRB 1410 robot and conduct series of accuracy & repeatability tests using FaroArm.
My questions are
i) Is there any physical identification marker on the robot which can be used to identify the location of base co-ordinate frame?
ii) If locating the base frame is not possible, can accuracy be measured from fixed arbitrary point in space?
There is reference points on the robot for calibration, including one on the base.
Page 123 of this manual lists them: http://lecture.sccsc.edu/amt/AMT%20206%20Electricity%20and%20Automation/ABB%20IRB%20140%20Robot/files/3HAC026320-001_revB_en.pdf
ABB does not calibrate the robot by finding the x,y,z position of the effector hand by direct measurement. They calculate it by zeroing the joints rotation sensors, and using that to 'blind reckon' x,y,z position from the 'home position'
The problem is that the manufacturers calibration system requires the manufacturers special pendulum calibration tool. More details on the mark locations and the calibration process is this manual: http://www2.tec.ilstu.edu/students/ABB%20Robots/IRB1600_Manuals/files/3HAC16578-1_revC_en.pdf
You may be able to rent the calibrator from ABB.
If you don't have the calibration tool, then you may be able to reference using a machinists level, a accurate ruler, and a fair amount of patience!
