I built EKF and UKF SLAM algorithms. The problem is that I expected to see a difference because of the more precise approximation of the system in the UKF.
Here's a screenshot from the estimated path from both filters [sorry about the German]:
As you can see, the differences are very minor and sum up to an equal performance of both filters within the mean errors for every estimated state. I thought increasing the system noise for a bigger uncertainty would make the advantages of the UKF clearer but it didn't make a difference.
UKF Parameters: $\alpha$: 0.01, $\kappa$: 0, $\beta$: 0.
My question is, what could be the reason for the similiar results of both filters and how can we enhence the UKF performance?
Thanks.
Nvm, the result improved with UKF parameters from a backup. The parameters where to low. New Parameters: $\alpha$: 0.5, $\kappa$: 25, $\beta$: 2.
Mean error X-Position
EKF 0.7572
UKF 0.2501
mean error Y-Position
EKF 0.4535
UKF 0.1708
Mean error orientation
EKF 0.0112
UKF 0.0083
