i have a question about the output of lidar sendor (like velodyne vlp-16, etc)
Is there any spatial or temporal locality for output data which is from lidar sensor? Does the produced output data from lidar sensor are stored in memory position sequentially or randomly? (which means that if a data from 0x000 and 0x001 point are spatially or temporally related.)
I see that lidar output data is obtained by spherical coordinate system and converted to cartesian coordiate system. (FIG 9-1, https://greenvalleyintl.com/wp-content/uploads/2019/02/Velodyne-LiDAR-VLP-16-User-Manual.pdf)
And there is a driver code to make un-ordered point cloud data to ordered data (https://github.com/ros-drivers/velodyne/blob/master/velodyne_pointcloud/include/velodyne_pointcloud/organized_cloudXYZIRT.h)
So, i guess lidar sensor is rotating 360' and sequentially produce the output and save them to certain memory location. So, is that possible to presume that memory address could give us hint for point cloud data information even before the ordering process?
Thank you. If i have some lidar sensor, then this question could be solved easily. but i don't have one.
