You can certainly employ ode23
to solve this ordinary differential equation, but it's much simpler if you recruit the state space approach via ss
and then lsim
The response of a linear system is always the aggregate of its forced (with a null initial state) and unforced evolutions (with $T_1=0$ and a given initial state $\mathbf{x}_0$).
The unforced evolution can be determined by means of initial
So, to answer your direct question, the initial conditions (read the initial state) are crucial as they establish part of the transient response of the system.
% parameters
N2 = 90;
N1 = 36;
Jn1 = 0.5;
Jn2 = 0.8;
J2 = 2;
D = 8;
K = 5;
J = (N2/N1)^2 * Jn1 + Jn2 + J2;
% define the system
sys = ss([0 1; -K/J -D/J], [0; N2/(N1*J)], [1 0], 0);
% initial state: (position, velocity) [rad; rad/s]
x0 = [0.1; 0];
% define the time span
t = linspace(0, 15, 10000)';
% define the input step
T1 = zeros(length(t), 1);
T1(t>=1) = 1;
% compute the system step response at once
theta1 = lsim(sys, T1, t, x0);
% compute the system response as aggregate of the forced and unforced
% temporal evolutions
theta2 = lsim(sys, T1, t, [0; 0]) + initial(sys, x0, t);
% plot results
figure('color', 'white');
hold on;
yyaxis left;
plot(t, T1, '-.', 'linewidth', 2);
ylabel('[N]');
yyaxis right;
plot(t, theta1, 'linewidth', 3);
plot(t, theta2, 'k--');
xlabel('t [s]');
ylabel('[rad]');
grid minor;
legend({'$T_1$', '$\theta_1$', '$\theta_2$'}, 'Interpreter', 'latex',...
'location', 'southeast');
hold off;
Here's the resulting plot:
If you really want to use ode23
, then you can run the following snippet:
x0 = [0.1; 0];
% integrate the differential equation
[t, x] = ode23(@fun, t, x0);
% plot results
plot(t, x(:, 1));
xlabel('t [s]');
ylabel('[rad]');
grid minor;
legend({'$\theta$'}, 'Interpreter', 'latex', 'location', 'southeast');
function g = fun(t, x)
% parameters
N2 = 90;
N1 = 36;
Jn1 = 0.5;
Jn2 = 0.8;
J2 = 2;
D = 8;
K = 5;
% compute gradient
g = zeros(2, 1);
g(1) = x(2);
g(2) = (-K/J)*x(1) + (-D/J)*x(2) + (N2/(N1*J)*(t>=1));
end
yielding the graph below:
Finally, if you aim to integrate a generic input as a function of time $t$, you could resort to the code below:
function x = integrate(t, u, x0)
% parameters
N2 = 90;
N1 = 36;
Jn1 = 0.5;
Jn2 = 0.8;
J2 = 2;
D = 8;
K = 5;
% plot results
% plot position
yyaxis left;
plot(t, x(:, 1));
ylabel('$x$ [rad]', 'Interpreter', 'latex');
% plot velocity
yyaxis right;
plot(t, x(:, 2));
ylabel('$\dot{x}$ [rad/s]', 'Interpreter', 'latex');
grid minor;
xlabel('$t$ [s]', 'Interpreter', 'latex');
g = zeros(2, 1);
g(1) = x(2);
g(2) = (-K/J)*x(1) + (-D/J)*x(2) + (N2/(N1*J)*u(t));
end
end
You can now employ anonymous functions to specify the temporal evolution of the input. For example, if the input is sinusoidal with pulse frequency $\omega = 0.5 \; \text{rad/s}$, you'll need to run:
x0 = [0.1; 0];
integrate(t, @(t)(sin(0.5*t)), x0);
to get:
