When I put my shaft through the vehicle body (small robot) and have the motor attached to it through two rotating gears, the shaft isn’t rotating?
I think it’s due to how the hole diameter is the same as the shaft diameter? Do I need to put a component in between the hole and shaft to allow rotation please?
Thank you
