I understand the functioning of Particle Filters from the book Probabilistic Robotics and the robotics course provided by Cyrill Stachniss.
I want to implement, from scratch, a particle filter to estimate the tilt angle $\theta$, angular velocity $\omega := \dot\theta$ and bias $b$ in one direction. I want to implement the most basic PF version as shown below. I have the mathematical model (that I can't post here for legal reasons) to do so when I was learning Kalman Filters in a University course. To explain in short, I have a process model, \begin{equation} x_k = A x_{t-1}, \end{equation} and a corresponding motion uncertainty matrix $Q$. Similarly, I have a measurement model, \begin{equation} z_t = C x_t, \end{equation} and the measurement covariance matrix $R$.
How do I go from this model to implementing the same in Particle Filters? PF requires to sample from the probabilistic state transition model: \begin{equation} x \sim p(x_t ~ | ~ x_{t-1}, u_t). \end{equation} Then, how do I assign a weight to each particle? That is, how do I evaluate this step of the algorithm \begin{equation} w = p(z_t ~ | ~ x_{t}), \end{equation} which requires evaluating the posterior for each particle $x_t$. I want to implement the most basic PF algorithm shown below, which I was able to do with Kalman Filters.
Particle Filter Algorithm from Probabilistic Robotics
The simplest way to construct $$x \sim p(x_t | x_{t-1}, u)$$ if you have $$x_t = Ax_{t-1}$$ is to just use $$x_t = Ax_{t-1} + \mathcal{N}(0,R)$$ where R is some process noise. You may way to sample from a more complex distribution.
Similarly, to construct $$p(z_t | x_t)$$ you can just use $$\mathcal{N}(Cx_t,Q)$$ (again you may want to use some more complex distribution)
$R$ is your process noise, $Q$ is your sensor noise.
As an addendum, Probabilistic Robotics has a whole chapter on constructing these probabilities for particle filters.
5
  • $\begingroup$ thanks a lot. I still do not understand how would we compare $z_t$ to the expected measurement $C x_t$. $p(z_t | x_t)$ should give us a probability value for each hypothetical particle $x_t$. $\mathcal{N}(Cx_t,Q)$ does not incorporate the real measurement anywhere. By the way, I am in the process of reading Probabilistic Robotics in an unstructured way. Can you please tell me which chapter talks about constructing these probabilities? $\endgroup$ Dec 30, 2020 at 0:02
  • $\begingroup$ To calculate $P(z_t | x_t)$ given $\mathcal{N}(Cx_t,Q)$ you can use the normal distribution liklihood which would be calculated like $L(z_t) = (2\pi)^{k/2} det(Q)^{1/2} e^{1/2 (z_t - Cx_t)^T Q^{-1} (z_t - Cx_t}) $ $\endgroup$ Dec 31, 2020 at 0:13
  • $\begingroup$ Chapter 4.2 discusses the particle filter. Chapter 5 and 6 discuss computing these probabilities. $\endgroup$ Dec 31, 2020 at 0:15
  • $\begingroup$ Hi. So, I tried using $L(z_t)$ to assign weight to each particle, but somehow each particle has weight 0.0. I realised, through a conversation with someone, that $L(z_t)$ is a density function and that we'd need to integrate (in $[a, b]$) it to get the likelihood of being in that range. $\endgroup$ Jan 14, 2021 at 14:16
  • $\begingroup$ Additionally, I read Chapters 5 and 6. Chapter 5 gives a good idea of sampling from the state transition model. Though it only talks about motion models for mobile robots I could still understand how to use it in my case. BUT, Chapter 6 mainly only talks about models for range finders. There is no discussion of working with a given measurement model (which, I assume, is fair, given that it is a book for mobile robotics). $\endgroup$ Jan 14, 2021 at 14:28
