When running a command similar to the roslaunch gazebo_ros empty_world.launch of the Tutorial: Using roslaunch to start Gazebo, world files and URDF models, I get the following error:
[Err] [Plugin.hh:180] Failed to load plugin libgazebo[...]: libgazebo[...]: cannot open shared object file: No such file or directory
How to solve this?
Solution was to remove the catkin workspace and install it again.
Remove: In your catkin workspace, usually your project folder, delete (or rename with suffix "_old" if you want to compare the not working catkin workspace later with the working catkin workspace):
  • build
  • devel
  • optionally src/CMakeLists.txt (I did that, not sure if it is really needed)
Source: Removing catkin workspace
Afterwards, the fresh catkin_make -j8 (or whatever catkin command you use) in my catkin workspace in the Python base environment installed without errors and the roslaunch command ran through.
