I am currently working on a project for school where I need to implement an extended Kalman Filter for a point robot with a laser scanner. The Robot can rotate with 0 degree turn radius and drive forward. All motions are piecewise linear (drive,rotate,drive).
The simulator we are using does not support acceleration, all motion is instantaneous.
We also have a known map (png image) that we need to localize in. We can ray trace in the image in order to simulate laser scans.
My partner and I are little confused as to the motion and sensor models we'll need to use.
So far we are modelling the state as a vector $(x,y,\theta)$.
We are using the update equations as follows
void kalman::predict(const nav_msgs::Odometry msg){
this->X[0] += linear * dt * cos( X[2] ); //x
this->X[1] += linear * dt * sin( X[2] ); //y
this->X[2] += angular * dt; //theta
this->F(0,2) = -linear * dt * sin( X[2] ); //t+1 ?
this->F(1,2) = linear * dt * cos( X[2] ); //t+1 ?
P = F * P * F.t() + Q;
this->linear = msg.twist.twist.linear.x;
this->angular = msg.twist.twist.angular.z;
return;
We thought we had everything working until we noticed that we forgot to initialize P
and that it was zero, meaning that there was no correction happening. Apparently our propagation was very accurate as we haven't yet introduced noise into the system.
For the motion model we are using the following matrix for F:
$F = \begin{bmatrix}1 & 0 & -v*\Delta t*sin(\theta) \\ 0 & 1 & v*\Delta t*cos(\theta) \\ 0 & 0 & 1 \end{bmatrix}$
As its the Jacobian of our update formulas. Is this correct?
For the sensor model we are approximating the Jacobian (H) by taking finite differences of the robots $x$, $y$ and $\theta$ positions and ray tracing in the map. We talked to the TA who said that this would work but I'm still unsure it will. Our prof is away so we can't ask him unfortunately. We are using 3 laser measurements per correction step so H is a 3x3.
The other issue where having how to initialize P. We tried 1,10,100 and they all place the robot outside the map at (-90,-70) when the map is only 50x50.
The code for our project can be found here: https://github.com/en4bz/kalman/blob/master/src/kalman.cpp
Any advice is greatly appreciated.
EDIT:
At this point I've gotten the filter to stabilize with basic movement noise but no actual movement. As soon as the robot starts to move the filter diverges quite quickly and exits the map.
