I've tried to create a URDF model of an arm robot similar to the following links using Solidworks to URDF plugin. This plugin creates a hierarchy relation between joint and links in any robot mechanism
https://grabcad.com/library/robot-arm-assembly-1
however, I've noticed this robot arm style has a couple of interaction links & joints that is not easy to make simple child-parent tree links.
I've trying to extract the child-parent link relations according to the following image
for example, the child-parent relation of link 1 is not clear for me, however, I made the following child-parent tree according to that image
I really appreciated any tip that helps me verify my design
