I cloned a gazebo ROS package from https://github.com/YugAjmera/omni3ros_pkg and if I try to do catkin_make,I get the following error. I am using Gazebo 11 and ROS Noetic and i've made sure to source the shell. error
I am new to ROS and Gazebo. It will be helpful if someone help me resolve this, Thanks!
  • $\begingroup$ Welcome to Robotics, Abhinandan K. There are two suggested solutions given in your screenshot. Did you try either of them? What happened? $\endgroup$ – Chuck Oct 31 '20 at 22:23
  • $\begingroup$ run the command rospack list and check if you have gazebo items (ex: gazebo-dev, gazebo-msgs, etc...). What happens when you type gazebo into the terminal? does Gazebo start? At first blush it looks like you are missing Gazebo. How did you install ROS? I recommend the full-desktop-install. $\endgroup$ – Mike Oct 31 '20 at 23:46
  • $\begingroup$ @Mike Yes I have installed gazebo, it runs when I type gazebo in the terminal, gazebo runs when I run a different gazebo launch file from a different package, I might be missing something in the current package $\endgroup$ – Abhinandan K Nov 1 '20 at 6:47
  • $\begingroup$ @Chuck I did not know what to do for the solutions mentioned in the error, I'd be helpful if someone shed more light on that, Thanks! $\endgroup$ – Abhinandan K Nov 1 '20 at 6:50
From the error screenshot you posted:
Add the installation prefix of "gazebo" to CMAKE_PREFIX_PATH or set "gazebo_DIR" to a directory containing one of the above files. If "gazebo" provides a separate development package or SDK, be sure it has been installed.
Since you said that you have gazebo installed, do you have the reference set in gazebo_DIR? Find what gazebo_DIR is currently set to, find where the gazeboConfig.cmake or gazebo-config.cmake files are located on your computer, and check that the two directories match.
