I am trying to get the usb.find
command to work properly in a python script I'm writing on Angstrom for the Beagleboard.
Here is my code:
#!/usr/bin/env python
import usb.core
import usb.util
import usb.backend.libusb01 as libusb
PYUSB_DEBUG_LEVEL = 'debug'
# find our device
# Bus 002 Device 006: ID 1208:0815
# idVendor 0x1208
# idProduct 0x0815
# dev = usb.core.find(idVendor=0xfffe, idProduct=0x0001)
# iManufacturer 1 TOROBOT.com
dev = usb.core.find(idVendor=0x1208, idProduct=0x0815,
backend=libusb.get_backend() )
I don't know what's missing, but here is what I do know.
When I don't specify the backend, no backend is found. When I do specify the backend usb.backend.libusb01
I get the following error:
root@beagleboard:~/servo# ./pyServo.py
File "./pyServo.py", line 17, in <module>
dev = usb.core.find(idVendor=0x1208, idProduct=0x0815, backend=libusb.get_backend() )
File "/usr/lib/python2.6/site-packages/usb/core.py", line 854, in find
return _interop._next(device_iter(k, v))
File "/usr/lib/python2.6/site-packages/usb/_interop.py", line 60, in _next
return next(iter)
File "/usr/lib/python2.6/site-packages/usb/core.py", line 821, in device_iter
for dev in backend.enumerate_devices():
File "/usr/lib/python2.6/site-packages/usb/backend/libusb01.py", line 390, in enumerate_devices
_check(_lib.usb_find_busses())
File "/usr/lib/python2.6/ctypes/__init__.py", line 366, in __getattr__
func = self.__getitem__(name)
File "/usr/lib/python2.6/ctypes/__init__.py", line 371, in __getitem__
func = self._FuncPtr((name_or_ordinal, self))
AttributeError: python: undefined symbol: usb_find_busses
What am I missing so that this will work properly?
Thank you.
