I wonder that horns for servos are marked in some T
units. Example: 25T
Please help me getting out, what does it mean.
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityI wonder that horns for servos are marked in some T
units. Example: 25T
The T
indicates the number of teeth or ridges in the servo spline. You need to match the servo spline to any device splines or they won't mate.
:EDIT: Because it's a good link, and because I hate it when links to resources rot, I figured I'd duplicate the information here from the excellent Servo City:
Servo Splines
Servos have an output shaft that typically uses a splined profile in order to transfer the torque from the output shaft into the servo attachment that is fastened to it. This splined profile is typically classified by the number of teeth, however, there is potential for two very different servo splines to have the same tooth count as it doesn't capture the spline diameter or tooth profile. For example, A15T and D15T both have 15 teeth, however the D15T is a much larger spline size than the A15T. The graphics below are loose representations of the common spline sizes that are found on hobby servos. If you have a servo that we do not offer on the site, you can check to see if your servo has a spline that matches any of the below spline profiles by counting the teeth and measuring the distance across the spline.
teeth
have some standard dimensions? Ex, pitch 2mm and pitch 1mm are comletely different cogwheels
– filimonic
Oct 15 '20 at 16:13
25 tooth (H25T Spline) spline
- so it's an H25T standard spline. B25T splines are not compatible. Hope this helps.
– Chuck
Oct 15 '20 at 17:23
