I'm trying to design a controller for a path-planning robot using Artificial Potnetial Functions [Prof. Howie Choset, Page 6 and 9, $\nabla D(q)$] and had a question about calculating the gradients of the potential functions to generate the force.
From what I understand, the attractive and repulsive force is calculated from the gradient of the attractive and repulsive potentials, i.e. $\nabla f_{a}$ and $\nabla f_{r}$.
$\begin{equation} f_{r} = \begin{cases} \eta * (1/d(q, q_{o}) - 1/\rho_{o}))^2, && d(q, q_{o}) \leq \rho_{o} \\ 0, && d(q, q_{o}) > \rho_{o} \end{cases} \tag{1} \end{equation}$
$\begin{equation} f_{a} = \epsilon * d(q, q_{g})^2 \tag{2} \end{equation}$
$q$, $q_{o}$ and $q_{g}$ are the coordinates of location of the agent, nearest obstacle and the goal respectively. $\rho_{o}$ is the repulsive radius of each obstacle. $d$ is the Euclidean distance.
This gradient operation on each of the potentials in (1), (2), yields an $x$ and a $y$ component, which are the $x$ and the $y$ components of the gradient vector at that point. We then combine all the horizontal components and the vertical components to calculate the angle, $\theta$, of the resultant force $F_{r}$ with the horizontal.
Is this the right approach or am I misinterpretating the $\nabla$ operations? The $X$ and the $Y$ components of the gradient at each point have to be computed seperately and then combined or am I missing something here?
Any and all help is appreciated!
