I am using a 1D lidar in one of my projects and it returns the distance it measures, in millimeters (mm). At some point in time, it gives garbage values that go as high as 10,000 or higher, when the value is expected to be under 200.
To mitigate such such outliers, I though of using a Kalman filter. Although it is something new to me, I used this MEDIUM blog as a start and tried modifying his code to suit my case.
I have the following data enter image description here. The visible peaks are the noise I added.
I create a live kalman filter as:
import numpy as np
import math
from numpy import  dot
from numpy.linalg import inv
class kf():
    def __init__(self):
        ### Defining filter
        #Transition Matrix
        self.F = np.array([[1.0]])
        #Observation Matrix
        self.H = np.array([[1.0]])
        #Process Noise Covariance
        self.Q = np.array([[0.09]])  # how much I trust the model
        #Measurement Noise Covariance
        self.R = np.array([[0.2*0.2]])
        # Control action Matrix
        self.B = np.array([1])
        #Control input
        self.U = np.array([1])
        #Covariance Matrix
        self.P = 1.0
        self.x_old = 100.0
    def filter(self, y):
        x_old = self.x_old
        F = self.F
        B = self.B
        U = self.U
        P = self.P
        Q = self.Q
        H = self.H
        R = self.R
        I = np.identity(1)
        Prediction
        x = dot(F, x_old) + dot(B, U)
        P = dot(F, dot(P, F.T)) + Q
        Innovation
        e = y - H*x
        S = dot(H, dot(P, H.T)) + R
        Mahalanobis distance approximation
        MD = math.sqrt(e*e)/S
        #Weighted MD
        MDw = 1/(1+(math.exp(-MD) + 0.9))
        #New Measurement Noise Covariance
        R = np.array([[4*MDw]]) # bigger the R, the lesser the trust the system will have on the sensor measurement.
        #Kalman gain
        K = dot(P, dot(H.T, inv(S)))
        Update
        x_new = x + dot(K, dot(e,K))
        self.x_old = x_new
        self.P = dot(I - dot(K,H), P)
        return x_new, x
And run as instance of this class each time I read the lidar value. The results are, (ignore the blue plot) ignore the blue plot
I expected the filter to not be so severly affected by the outliers, I am new to this field and hence tried playing with the tunable parameters but to no gain :/
Where am I going wrong ? Is there any other non-computation-intense method for filtering data in real time ?
  • $\begingroup$ Have you tried to ignore the outliers, i.e. only do a prediction step and not a correction step with the Kalman filter? $\endgroup$
    – fibonatic
    Sep 30, 2020 at 20:17
You are calculating the new R, but you're not using it. You just replace the new R with the line R = self.R.
You are not removing the outliers, because you are ditching that result!
  • $\begingroup$ Thanks @bruno :) Kudos ! $\endgroup$
    – Pe Dro
    Oct 1, 2020 at 2:31
