//ERROR: Task 'autonomous' is not defined at global scope level
#pragma config(StandardModel, "RVW CLAWBOT")
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
#pragma DebuggerWindows("joystickSimple")
task autonomous();
task main()
while (true)
    // update buttons and joysticks
    getJoystickSettings(joystick);
    //Assign the left and right joystick values
    //to the left and right motors
    motor[leftMotor] = joystick.joy1_y1;
    motor[rightMotor] = joystick.joy1_y1;
task autonomous()
    motor[leftMotor] = 80;
    motor[rightMotor] = 80;
    wait1Msec(2500);
    motor[leftMotor] = 0;
    motor[rightMotor] = 0;
    wait1Msec(1000);
    motor[rightMotor] = -80;
    wait1Msec(2500);
    if(motor[rightMotor] == 1) {
    startTask(autonomous);
    stopTask(main);
  • $\begingroup$ your code is badly formatted ... if you use correct indentation, then you may be able to see your error $\endgroup$
    – jsotola
    Commented Sep 26, 2020 at 23:52
The code for “task autonomous()” should be outside of the main() function.
