My ROS-system was working pretty well.
Then, I installed rosdep by using sudo apt install python-rosdep2, which ended fine without showing any issues. Then I issued
sudo rosdep init
sudo rosdep update
which also ended without showing issues.
But now, my ROS-installation seems to be broken because I can't source my ROS any more!
For example, typing ROS-commands, such as
roscore or rqt
results in:
enter image description here
Sourcing, as usual with source /opt/ros/meldoic/setub.bash makes no difference.
What has happened? How to fix this?
Additional Info:
Typing ros<tab><tab> only shows me the following options anymore:
Where is all the rest gone?
Install ROS properly again using (Just execute this command, don't worry nothing will be installed twice) sudo apt-get update
sudo apt-get install ros-melodic-desktop-full
also source your ROS packages using (there seems to be a typo in what you've typed above)
source /opt/ros/melodic/setup.bash
You can add this line to your .bashrc file so your ROS automatically get sourced everytime you open any terminal.
rosdep update should be run without sudo. ROS wiki/rosdep.
sudo rosdep init
rosdep update ## without sudo
Running rosdep update again might solve your problem, although I haven't encountered this specific problem myself. Further steps to investigate could be to search for the commands you are missing (rqt, rostopic). For example search for roscore:
find /opt/ros/$ROS_DISTRO/bin -iname roscore
$ROS_DISTRO might need to be manually to your ROS distribution (for example noetic).
Edit: The following rosdep command will attempt to fix the permission issue.
rosdep fix-permissions
According to the rosdep man page:
rosdep fix-permissions: "Recursively change the permissions of the user's ros home directory. May require sudo. Can be useful to fix permissions after calling "rosdep update" with sudo accidentally."
