I have a skid steer robot where I have four individual DC motors with an H bridge so I can control speed and direction. There are also four quadrature encoders with 6000 ticks per revolution. The motors are 12v and I am controlling them with a 10bit PWM (0 to 1023). First test I did was to raise all wheels and test the minimum value where the wheels start moving, which is around 500.
I am able to measure the current speed of the wheels correctly by using a counter where the quadrature encoder set it to count up or down. Therefore, by reading the current count every 50ms (20Hz), I can measure the current speed:
encoders_curr.FR = COUNTER_mReadReg(ENC0_BASEADDR, COUNTER_S00_AXI_SLV_REG1_OFFSET);
encoders_curr.FL = COUNTER_mReadReg(ENC1_BASEADDR, COUNTER_S00_AXI_SLV_REG1_OFFSET);
encoders_curr.RR = COUNTER_mReadReg(ENC2_BASEADDR, COUNTER_S00_AXI_SLV_REG1_OFFSET);
encoders_curr.RL = COUNTER_mReadReg(ENC3_BASEADDR, COUNTER_S00_AXI_SLV_REG1_OFFSET);
encoders_diff.FR = encoders_curr.FR - encoders_prev.FR;
encoders_diff.FL = encoders_curr.FL - encoders_prev.FL;
encoders_diff.RL = encoders_curr.RL - encoders_prev.RL;
encoders_diff.RR = encoders_curr.RR - encoders_prev.RR;
encoders_prev = encoders_curr;
speed_measured.FR = (2*M_PI*WHEEL_RADIUS*encoders_diff.FR) / (0.05*TICKS);
speed_measured.FL = (2*M_PI*WHEEL_RADIUS*encoders_diff.FL) / (0.05*TICKS);
speed_measured.RR = (2*M_PI*WHEEL_RADIUS*encoders_diff.RR) / (0.05*TICKS);
speed_measured.RL = (2*M_PI*WHEEL_RADIUS*encoders_diff.RL) / (0.05*TICKS);
Which I convert to X, Y and Z with:
// Inverse Kinematics: http://robotsforroboticists.com/drive-kinematics/
kinematics_measured.linear.x = (speed_measured.FR+speed_measured.FL+speed_measured.RR+speed_measured.RL)*(WHEEL_RADIUS/4);
kinematics_measured.linear.y = (-speed_measured.FR+speed_measured.FL+speed_measured.RR-speed_measured.RL)*(WHEEL_RADIUS/4);
kinematics_measured.angular.z = (-speed_measured.FR+speed_measured.FL-speed_measured.RR+speed_measured.RL)*(WHEEL_RADIUS/(4*(WHEEL_SEPARATION_WIDTH+WHEEL_SEPARATION_LENGTH)));
Now for the control part, to set the individual velocities of each of the four wheels, I am using these equations, as my input is linear x, linear Y and angular Z speeds (rad/seg):
// Forward kinematics: http://robotsforroboticists.com/drive-kinematics/
speed_desired.FL = (1/WHEEL_RADIUS)*(kinematics_desired.linear.x-kinematics_desired.linear.y-kinematics_desired.angular.z*(WHEEL_SEPARATION_LENGTH+WHEEL_SEPARATION_WIDTH));
speed_desired.FR = (1/WHEEL_RADIUS)*(kinematics_desired.linear.x+kinematics_desired.linear.y+kinematics_desired.angular.z*(WHEEL_SEPARATION_LENGTH+WHEEL_SEPARATION_WIDTH));
speed_desired.RL = (1/WHEEL_RADIUS)*(kinematics_desired.linear.x+kinematics_desired.linear.y-kinematics_desired.angular.z*(WHEEL_SEPARATION_LENGTH+WHEEL_SEPARATION_WIDTH));
speed_desired.RR = (1/WHEEL_RADIUS)*(kinematics_desired.linear.x-kinematics_desired.linear.y+kinematics_desired.angular.z*(WHEEL_SEPARATION_LENGTH+WHEEL_SEPARATION_WIDTH));
The PID function that I have implemented is the following:
float integral=0.0, prev_error=0.0;
#define dt 0.05 // in seconds
#define Kp 1
#define Ki 0
#define Kd 0
float pid(float desired, float measured)
if(measured<0)
measured = (-1)*measured;
// Calculate error
float error = desired-measured;
// Proportional term
float Pout = Kp*error;
// Integral term
integral += error*dt;
float Iout = Ki*integral;
// Derivate term
float derivate = (error-prev_error)/dt;
float Dout = Kd*derivate;
return (Pout+Iout+Dout);
So, after measuring the current speed, I can call it to obtain the speed I need to set the duty
of each motor.
My questions:
- The sign of the velocity indicates the direction of rotation (clockwise=forward, counterclockwise=backwards). Do I need to pass to the pid function the desired velocity as a signed or unsigned value?
- What should I do with velocity values that would mean a lower pwm so the motor will not spin?
- To convert from linear velocity that the pid will dictate to duty cycle, I am calculating the equation that passes over two points. For this, I measured the speeds at the minimum and maximum duties where the wheels rotation (500 and 1023) giving (0.81 and 1.03). I use these numbers to get the equation:
p = 511 + (uint16_t)(((1023-511)/(1.02-0.8))*(v-0.8));
. Should I consider that the speed can be negative to compute a "negative" duty which will later represent only the direction to set for the motors? If so, it means that I have to consider that the two points for the equation are (-1023, -1.03) and (1023, 1.03)? - As I have four motors, they all show different velocities. So, to simplify the process, even thought there will be 4 PIDs, I got for the lowest duty cycle the maximum velocity value of all motors and for the highest duty cycle the lowest velocity of all motors. Would that be correct?
- Do I need to include the speed limits for the PID?
- Considering the signs, won't be a problem if the measured speed is higher than the desired, the pid would compute a negative value and the fact that the rotation switches directions might cause an issue, or not?
Thank you for the help.
